Help Connecting PC to SLC5/04
gizmo
Aug 2002
95
I'm tring to connect a laptop to a SLC5/04 Processor.
I can take the laptop and connect cable between 1784-PCMK Card @ PC(RSLogix 500) and the Programming Port on front of a test processor in a test/bench rack. I see it in RSLinx and able to download to it.
I take out test processor and plug NEW out of the box Processor, reconnect cable and do everything the same as before but never see it in RSLinx.
What did I need to do or verify to be able to connect?
I realize this is very brief (no part numbers, versions and etc.). I do not have access to them from this location.
Any help would be greatly appreciated.
The default DH+ node address of the SLC 5/04 is node 1, if you have anything else with that address, you will have a conflict. What is the node address of your laptop, I usually set mine for Node 63.
Change your PC address to 2 or 3. See if that solves the problem. Maybe your DH+ address is somehow changed.
Next, check your Baud rate. Maybe the new processor is shipped with 230k baud rate.
If that doesn't work, take the processor out of the rack, unplug the battery, and short the connections that have the large capacitor soldered to the PC board. Leave this connection shorted for about 5 seconds.
This should put the default processor communications back. (if it was ever changed)
Put it back in and test it.
If all fails, use your serial port and get online and look at the DH+ connection settings......
This may take longer than 5 seconds. I've waited up to a full minute before I was assured that the old program was deleted and the factory defaults restored...
Followup
I'll try the recommendations above. The PLC is located in a remote location with no phone or internet.
If it helps any, I took my test SLC5/04 processor which was Node 4 and Cleared its program.
Powered everything back up and RSLinx communicated with it at Node 1.
How do I check Baud rate and other comm parameters for that 1784-PCMK driver?
Anyone know off the top of their head what the default settings are?
In your Rslinx driver setup, there is a pulldown menu that shows what speed to use. I think that only version b card supports 230+.
It is just a stab in the dark.
Try here
Another stab in the dark...
Could you have an old version of RS Linx and an old processor on your test stand, but your 5/04 is too new to be compatible?
Post your versions of each of the three items:
1) RS Linx
2) Old test stand PLC
3) New processor
I'm having an issue getting online with a PLC SLC 5/05 on the network. I have gone online with other processors over Ethernet but these are giving...
1,998
Hello all, hope your week is going well. I am currently working on debugging a Micro850 with Category number 2080-LC50-24QWB. When I connect...
2,397
Hi all Has anyone connected a baumer verisens vision to a tia I have set up the gsd file and have added the verisens to the network On setting...
3,098
Dear all, In a previous post I asked if someone had the software for an old Taian TP02. We used to sell our bandsaw machines with these PLCs a...
2,797
Hello all. I have to connect to a Siemens S7-200 CPU 224-XP using a serial connection with DB9 to USB converter. The converter is connected and...
3,506
