Help converting Logicmaster file
hatemeid
Dec 2005
Alexandria
Dear All,:)
I have a program which was created using (logic Master 90-70 version "7.02" ) with CPU 90-70 , i want to replace this "OLD DOS Program" with new Windows one , i select "VersaPro 2.04 Professional edition" but when i am trying to do this
The following syntax errors appears in the information Windows during conversion::confused:
Hardware configuration successfully imported.
---------- Importing from: C:\Program Files\GE Fanuc Automation\VersaPro\HATEM. ----------
Processing: _MAIN.dec....
_MAIN.dec successfully processed.
Fatal Error: Entry destin is a type of subroutine declaration entry not supported.
Error: Unable to import the declarations file.
---------- Import complete. ----------
---------- Import failed. ----------
My questions Are:
1- which suitable new windows based program should i select to convert the old program "LM90"?
2-do i need any hardware modification for using the new selected program to communicate with my CPU 90-70 system for uploading and downloading , and logic forcing , and program editing?
Thanks For all
Your Cooperation is highly appreciated
I can think of two 90-70 subroutine types that could cause the problem. The first is a parameterized block. the second is a C block. Does your program include either of those?
Make a copy of your program for testing. Then delete subroutine blocks from it one at a time and try importing into VP without the deleted block until you identify which block is causing the problem. The first blocks you delete should be any non-ladder blocks.
Hello All and Steve Bailey, I have attached a Logicmaster file from an old GE 9030. The memory is lost and just bought GE Proficy ME to put it...
5,695
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
330
Hi! I am working on a project were we will be replacing an 300 CPU with a 1500 CPU and we are working on migrating / converting code. There is a...
1,080
Hi! I need help converting an old MicroLogix 1100 project to Micro 820. Project Details I have an old MicroLogix 1100 program that has been in...
476
Hope someone is really bored this late on Memorial day!!! I have spent the last 5 hours researching this and trying everything I could find on...
3,283
