help converting Memory Areas to new PLC
willwatson
Feb 2004
I'm changing our old C200H plc to a CS1G-H CPU42. I am able to convert the program with little trouble, but It will not convert the Memory areas. I get an error stating that its incompatible with the new plc. Does anyone know an easy way to convert this? I already swapped the plc's and dont really want to change them back. Almost forgot, the program was written and saved in LSS. That seems to be the big problem.
Any help would be great...Will Watson
I forgot, I have 2 high speed encoders, C200H-CT001, and the sales rep couldn't tell me if they were compatible with the new PLC. He said "they should work"
The C200H-CT001 modules are definitely compatible with the CS1 series of PLCs.
Conversion issues:
C200H allocated 10 words of I/O to the module starting at word 100 + 10xUnit number.
CS1 allocates the same module to word 2000 + 10xUnit Number
C200H allocated 100words of Data Memory starting at DM word 1000 + 100xUnit Number.
CS1 allocates the same module to DM word 20000 + 100xUnit Number.
AS far as your LSS conversion issues, zip all the files and post them here and we will take a look at them.
How did you convert from LSS to CX? I think you need to go by Syswin
That what I did I convert from LSS to Syswin then from Syswin to CX.
Then I relocated the I/O DM ......
It should not be problem.
Thanks guys for your help. My memory addressing was incorrect. Soon as I fixed that, everything was fine. Its good to know that there are other helpful people out there. I've only been involved in the PLC aspect of our plant for a few months and no one around here wants to talk about it. There seems to be alot of people that say "Figure it out yourself". There's even alot on this site. Hope I can help you someday...Will
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
330
Hi! I am working on a project were we will be replacing an 300 CPU with a 1500 CPU and we are working on migrating / converting code. There is a...
1,080
Hi! I need help converting an old MicroLogix 1100 project to Micro 820. Project Details I have an old MicroLogix 1100 program that has been in...
476
Hope someone is really bored this late on Memorial day!!! I have spent the last 5 hours researching this and trying everything I could find on...
3,283
I am needing to convert the low DWORD of a timestamp into a LREAL. The DWORD is a 32bit unsigned number. In TwinCat2, I keep getting a negative...
1,688
