help me problem with pointer stl s7-300
slentnight
Jan 2015
moscow
i write code STL and simulate but result Q2.7 not set , i dont know why :unsure: , help me plz thanks
LAR1 P#Q2.7
S [AR1,P#0.0]
or
LAR P#2.7
S Q[AR1,P#0.0]
Hello ,
the set command is missing.
Code:
      LAR1  P#Q 2.7
      SET
      S      [AR1,P#0.0]
Or you can select the input and output directly form code:
Code:
      L     P#0.0
      L     DW#16#81000000
      OD
      LAR1
      L     P#0.0
      L     DW#16#82000017
      OD
      LAR2
      A      [AR1,P#0.0]  I0.0
      =      [AR2,P#0.0]  Q2.7
40
This is the problem, I need to solve it using a ladder diagram: Write a table of inputs and outputs and propose a control solution for a screw...
22
3,954
Hey all, I am having an issue concerning the Modicon System Responsible for the operation of our Generator System. (Particularly Dresser-Rand...
2,564
49
10,786
please help i didn't solve this problem with rslogix. I counted but i am not using timer. How i will fix this situation? Please anyone solve this...
18
4,929
