Help needed! CitectSCADA 7.2 & AB 1756-L55/A
PoppinJar
May 2012
Singapore
Hi i am starting a project using CitectSCADA 7.2 with AB 1756-L55/A.
How do i get Citect to read the tags from the PLC?
How to i configure the boards, ports, I/O devices, server and tags in Citect 7.2?
I've been trying to read up the forums, i still can't manage to do it. I need help.
Thanks alot in advance.
Guys, i need help. I've attached a printscreen of all my communication forms. Please do help me check and point my errors.
my setup, slot 0: PLC, slot 1: EN2T. computer's IP: 192.168.1.10. en2t's IP: 192.168.1.1.
Thanks a million!
Poppinjar
OK you've shown us what you have done, good. (though its not easy to read at that resolution)
Have you run the Citect computer setup to make your machine a server?
is there a tag in the PLC named "test"?
Chris
yes. i have made my computer the server.
and yes, i have a tag named test in plc and running on program mode, i forced it to "1" and i create a text display in citect. When test, the text will show.
right now it is showing #BAD instead of #COM.
i am running citect kernel and this is what is shown.
"no driver configured" and "no unit statistics available as this is not an IO server"
any idea?
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
244
Hi I’m after some help , I have a plc program with a baumer verisens vision camera attached I have got the signals working ect but I have an...
963
Hi all, We are facing synching issues with redundancy module, where the Primary is ending up with disqualified secondary. Normally this would...
628
Hi all, I have got this machine that needs to be up and running soon. This machine has Schneider's Controller and I/O modules, 3 vfd's, 2...
915
Is it possible to write to the high speed counter function file "high speed preset" on an AB micro 1100. I have the HSC set up with a MOV...
1,088
