help needed for MAOC instruction
ibora
Dec 2008
Izmir
66
Hi everybody,
I'm working on a 5069-L306ERM CPU with 1732E-OB8M8 output module. I'm trying to produce cam signals with MAOC command. I have a 842E encoder. When i'm working on the program in my workshop I created a virtual axis and geared it to encoder axis. Than created MAOC command and configured. And i produced all cams for two outputs. In the field when i'm integrating the system to the machine i changed the "execution target" parameter from 0 to 2(also in axis parameter). Then i got error code 35. And then turned back all parameters but still i'm getting same error. Any idea?
explanation of error 35: The specified execution target exceeds the number of Output Cam targets configured for the axis.
Thank you for reply. But when parameter was set to 0 two outputs were produce cams
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
238
Hi I’m after some help , I have a plc program with a baumer verisens vision camera attached I have got the signals working ect but I have an...
961
Hi all, We are facing synching issues with redundancy module, where the Primary is ending up with disqualified secondary. Normally this would...
627
Hi all, I have got this machine that needs to be up and running soon. This machine has Schneider's Controller and I/O modules, 3 vfd's, 2...
912
Is it possible to write to the high speed counter function file "high speed preset" on an AB micro 1100. I have the HSC set up with a MOV...
1,086
