Help needed - to find time between 2 input signals
Preeya
Nov 2003
112
Hi everyone, I have an input that changes state frequently (in milliseconds). I need to find the time interval between 2 signals of this input. (ref diagram)
I tried to set a timer and reset it with the same input but it didn't seem to work. I am using a siemens S7 200 PLC.
Please help me! Thanks
Thanks for the logic Arik. Let me try that and see. But as I mentioned this input changes in millisecs so hopefully this logic works.
Siemens S7 200 has Input rising edge interrupt. But how do I use that? Also as this input changes frequently wouldn't the interrupt keep executing?
Try this.
I couldn't test it because I haven't simulator for S7-200 or any S7-200 PLC:s.
There are some 1ms resolution timers in S7-200 according to Microwin help: (TONR--> T0,T64 - TON,TOF-->T32,T96)
This logic seems to work.. I just tested on the S7 200. Thanks TS!
Thanks for your help too Arik.
If you try it with a Mitsubishi FX2N, you can use the first inputs with interrupts amd measure time input is ON, time OFF or period.
Can be measured with a resolution of 0.1ms.
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
230
Hi I’m after some help , I have a plc program with a baumer verisens vision camera attached I have got the signals working ect but I have an...
959
Hi all, We are facing synching issues with redundancy module, where the Primary is ending up with disqualified secondary. Normally this would...
625
Hi all, I have got this machine that needs to be up and running soon. This machine has Schneider's Controller and I/O modules, 3 vfd's, 2...
912
Is it possible to write to the high speed counter function file "high speed preset" on an AB micro 1100. I have the HSC set up with a MOV...
1,086
