Help required with an old PLC program
markhughes100
Mar 2017
Birmingham
I'm currently trying to open an old Medoc/Melsec (Mitsubishi DOS-based PC program) Does anyone know how convert it into windows based program? I have the SW0PC-FXGP/WIN-E converter program which should convert from DOS to windows but doesn't. Any advice!
I don't have specific experience with that system, but what I CAN do is help you getting it running on DOS via virtual machine if you have either a) an old copy of windows and b) the DOS version of the software.
There's a program out there called Dosbox. Check that out. That may get you going.
Nail on the head. Windows 98/ME/XP you could run dos programs or Dosbox. One of them in a VM and install the dos version of the software, though it being on a floppy may be an issue. Most floppies are dead these days as magnetic storage doesn't have a very high life span unless conditions are kept pretty pristine.
When installing GX Developer, there is an option to import medoc files and convert them.
There will be his option with Gpwin too.
Reinstall it and tick the box to import medoc files.
Hi all, I have a couple of projects that I created using Step 7 v5.5. We recently upgraded our software to v11, and I don't have access to the...
1,737
Hey, we got a machine from China (yay hooray -.-) that has some really annoying flaws. Like the HMI screen is going off after a minute which is...
2,170
I have the logic of OMRON but I want to do this logic in TIA 15.1 CPU 1200...
1,842
I have a small application where I need to spec out an actuator. The load is 7kg and needs to move 90 degrees around a 1cm diameter in 1 second...
1,856
i am using PLC of B&R its CPU is CS0104100242. It is showing Error 23 and when i reset this error its cpu shows "INIT" and again it shows error...
1,873
