Help Setting Up a New DeviceNet network
gkinslow
Jun 2006
the heartland
26
I have worked around a DeviceNet network, but never set one up. I am working on a project where I wanted to install DeviceNet system.
Essentially, I want to replicate one I seen done before. One I have worked on. I HAVE NEVER SETUP A DEVICENET NETWORK. I NEED HELP.
I was looking to install a
Micrologix 1500 / 1764-LRP
DeviceNet Scanner card 1769-SDN
DeviceNet PowerTap 1485T-P2T5-T5
DeviceNet CPU interface card 1784-PCD
I need to branch to 3 junction boxes within a 25 foot range. At each location I was going with,
1794-ADN communication adapter module
1794-IB16 Flex I/O input module
1794-0B16 Flex I/O output module
1794-TB3 Base for the input mod
1794-TB2 base for the output mod
Am I missing anything that I need. Furthermore, HOW DO I ACTUALLY SET THIS THING UP. I've been programming plc's for quite a few years, but never had to setup any type of network.
Checkout www.odva.org This is the official DNET site and can explain alot.
You will need RSNetworx and EDS files.
You will need DNET Power supply(s), depending on devices used you may need more than one.
Hello all I have a controllogix PLC with a 1756-DNB devicenet scanner module in it and I am trying to set up a devicenet network for the first...
5,018
I am working on setting up my own 1756 B series PLC rack, power supply 1756-PB75 /B, 1606-XLS480E -redundant 24 DC power supply, controller...
4,319
Hello all. I am having trouble setting up my HSC to count pulses from a prox switch. I have it wired to the prox and I see the .InputStateA0...
1,374
Hi everyone! First time posting to this, so should give you a bit of background info on myself to explain the situation i'm in. I am a beginner...
1,580
I am new to compactlogix 1769 L30ERM PLC. when I was upgrading firmware to version 30 through control flash flowing error came. it is; and also...
3,037
