Help with connecting and reading ethernet packages in plc-programs please!!
Fiddeflygare
Mar 2009
VƤrnamo, Sweden
Hi.
I am working on a project where the customer has inquired if it is possible to connect a barcode-reader to the plc to make the setting of orderspecific variables easier. Now i have asked the manufacturer of the plc and it is possible but only by ethernet connection on my system. I am using a bosch-rexroth MLD (internal PLC in a servodrive) and i am wondering if anyone in here has had experience in doing the same or similar programming?
The problem with the MLD is that i am forced to make a program that is divided in the same steps as a normal TCP/IP protocol is operating by o_O. I was tipped to use the library RIL_SocketComm.lib but i can't use that since i get a lot of errors from the FB:s in that library so i am forced to use the library SysLibSockets.lib instead šŸ™ƒ. Anyone here that can give me tips and trix about how to write and build the program so that i can read the header and data of the package sent by the barcode reader?
I have little experience of working with TCP/IP, Ethernet and i have absolutley never tried to send information to a PLC-program via Ethernet except from HMI:s where i already have programs to configure everything...
I don't know if you can do what are you trying to do. I did a program a while back with the Bosch MLD that needed a CanOpen device to send data back and forth and it caused much pain. Ended up having to get a special firmware from Bosch themselves.
I would think that you'd have to setup the data transfer in Indraworks as part of the Ethernet there.
Hello all, hope your week is going well. I am currently working on debugging a Micro850 with Category number 2080-LC50-24QWB. When I connect...
2,356
Hi all Has anyone connected a baumer verisens vision to a tia I have set up the gsd file and have added the verisens to the network On setting...
3,081
Dear all, In a previous post I asked if someone had the software for an old Taian TP02. We used to sell our bandsaw machines with these PLCs a...
2,781
Hello all. I have to connect to a Siemens S7-200 CPU 224-XP using a serial connection with DB9 to USB converter. The converter is connected and...
3,449
Hello, I have some EVAP units that use an an OPTO 22 SNAP-PAC-EB2 Brain to control I/O. I downloaded the latest basic software package from OPTO...
1,705
