Help with DL06 Ziplink choices
missionav
Oct 2006
NH
I'm having a hard time getting my order together for zinplink cables, and connector modules for the DL06 16 point inputs and outputs.
I'd prefer not to use them at all, and buy a 20 point plug, but it looks like there are no plugs available at automation directs site.
The ziplink pdf here: http://web4.automationdirect.com/static/specs/zipcables.pdf
tells me that I need to use ZL-CBL056 in order to use their feedthru module, but a seacrh of their site only gives me the choice of ZL-CBL056L and ZL-CBL056FR
Neither cable has the DB connector that the module ZL-CM056 seems to have in the picture (unless they changed it?).
If i use the ZL-CBL056L cable, I'd have to use the LED mudules. I don't quite understand how the unit works, as it has much more than the 20 terminals needed to access the IO on the 16 point I/O.
I have requested this info from automation direct, but haven't gotten an answer after a few days.
Any help would be appeciatted.
Dan
The ZL-CBL056 is the correct part number. I am looking into why it was omitted from our last store update. Until I can figure this out, you can phone in your order to 1(800)633-0405.
Can someone explain to me what exactly the SP62 is doing. I understand that SP62 is a greater than instruction but dont really understand its...
1,327
I've been out of programming PLC's for a 5 years, only some minor programming experience with some AB's and I've got myself into a small project...
2,141
I have a DL06 PLC from Automation direct and I am trying to learn how to use the expansions slots in my program. Coming off of allen Bradley...
20
6,232
Hello, I have a DL06 with a D0-Ecom100 card connected to a Keyence IL1000 Laser measurement device through a DL-EP1 ethernet comm module. Also...
4,397
I'm writing a program that determines the first outage in a series of limits. E-stop - Hi Limit - LGPS - HGPS - Exhaust Input Are all...
8,455
