I need help figuring out the addressing of an expansion slot DL06 PLC
Included with the module is several pinout decals. Use the ones that match the part number of your module. In this case, D0-16TD2.
The ZipLink pinout, etc. for DO-16TD2 is on page 2-27 of the Options manual. Download Chapter 2 or the entire manual here.
This is a sourcing module. It's output is positive.
Remove the wire from terminal 11. That wire goes to the negative of your light.
Remove the wire from terminal 12, and put it on terminal 2. This is the positive lead of your light.
EDIT: The wire from terminal 11 goes to C0, the last terminal on the right, as well as the negative of the lamp.
You are absolutely correct. I was under the assumption that the negative wire was what the plc controlled to turn the light on and off. It is the complete opposite, I switched the negative for the positive wire and I finally got it to work.
I cant tell you guys how much appreciate your knowledge and helpfulness. I took a couple classes in college with plc's and I have always like to just tinker with them as a hobby now. I have learned a lot from this forum and obviously still have a lot more learning to do (y)
Good afternoon to all, I have a machine that sends a 24 VDC signal out after cycle complete. This signal goes to the robot digitial I/O module...
2,059
Hi, I am fairly new in the PLC industry, and my latest job for me to complete is to test a panel with a single output module (Spectrum Control...
1,771
I'm having trouble configuring my 1734-OE4C 4ch analog out modules. I've read the docs but details on configuration is sketchy at best, at least...
3,633
I am trying to get a micrologix 1100 to communicate with my pv+ 400. I have quite a bit of experience with rs logix 500 but never have had to set...
3,957
Hi folks...I need some help getting a 1769HSC configured correctly. Here is what I need, in specific: I will need to use a directional counter...
1,535
