All,
I recently upgraded a Factory Talk View SE network distributed application from Version 7 to 9, the upgrade went well and the application is running.
I am not trying use the Distributed Application Manager tool to backup the application but it fails.
I can backup the application using the HMI backup and restore tool
I have contacted RA support but they are unable to find a solution.
Any ideas?
Thanks!
The error log reads:
Logging started: 04/18/17 09:02:31
08_32_Engineer 04/18/17 09:02:31 [INFO] Backup pre-checking : Checking APB file.
08_32_Engineer 04/18/17 09:02:31 [INFO] Backup pre-checking : Checking disk space.
08_32_Engineer 04/18/17 09:02:32 [INFO] Backup pre-checking : Checking FactoryTalk Directory Server.
08_32_Engineer 04/18/17 09:02:32 [INFO] Backup pre-checking : Checking HMI Server connectivity.
08_32_Engineer 04/18/17 09:02:37 [INFO] Backup : Starting to back up application 'Bolney 08_32 Steam Plant' to 'C:\Users\Administrator\Desktop\Bolney 08_32 Steam Plant.apb'.
08_32_Engineer 04/18/17 09:02:37 [INFO] Backup : Getting all HMI server information.
08_32_Engineer 04/18/17 09:02:39 [INFO] Backup : Backing up FactoryTalk Directory.
08_32_Engineer 04/18/17 09:22:41 [ERROR] Backup : Compression of HMI project 'FTVSE' failed.
08_32_Engineer 04/18/17 09:22:41 [ERROR] Backup : Backup failed! 0x80008008
Logging ended: 04/18/17 09:22:41
Any ideas?
Thanks!
