Mark Goldman
I have a used Honeywell UDC3300 (DC330B-KE-003-20-000000-20-0) that was once used to control the furnace on a strip anneal and now I want to use for the following functions:
1) Monitor two areas of a heated compartment via RTD, which is already being controlled for heat by different controller.
2) Provide two inputs to a PLC if either one of the RTD get to a set point.
I have both RTD wired, set up for 100 pt, and seem to be working correctly. +24 v to terminal 6 of CTL1, out of terminal 5 to an PLC input, and, for CTL2, +24 v to terminal 9, out of 8 to a PLC input.
Also, I was wondering if the Honeywell has a factory default that I can wipe out all previously programming to start fresh?
I know it's overkill using this controller for such a simple task but it's what I have and I'm on a budget. Besides, it was free.
Thanks in advance!
Thanks in advance!
