Help with Micrologix 1500
gizmo
Aug 2002
95
When I attempt to go Online with a Micrologix 1500, I get a "DiagnosticStatus Failed 0x10" message. I've attempted to connect via DF1 and ethernet but both paths give me the same error message.
Note: I beleive this problem started after attempted to modify the ML1500's CH 0 baud rate settings.
Any help with this problem would be great.
Thanks!
follow up
Thanks paraffin power
That's (auto configure in linx) what we had to do to get back online.
thanks again
I've attached pics, below. I'm in the field right now an am trying to communicate to the Micrologix 1500 through the 1761-NET-AIC (Ugh!) to...
1,954
Greetings First, I am very new to PLC and logic. I have managed to muddle my way through on most things but I'm stumped here. I use two systems...
2,903
I cannot open this old file with any of my versions of AB software. Would someone be able to generate a pdf of the file and send me the pdf? I...
2,788
Hello Great forum ! I have problems with a micrologix 1500 My intention is to send pulses using the PTO instruction output O:0/2 and O:0/3 on...
1,861
Rite now I am playing I do have a goal in mind but unsure how to get there. I have attached a Doc. Could anyone tell me why it doesn’t work. I am...
4,183
