Hello all. Hope to get some basic information on the Mitsubishi FX0S-30MR0ES PLC. I already downloaded any PDF I can find on the web on this unit. I am mainly interested in the analog potentiometer that is hiding next to the Run-Stop switch. I do not plan to reprogram this PLC as it is running fine. It is use to control a set of air compressors. I was told by a co-worker that I can adjust the motor run timer just by turning it with a small screw driver, which I do not believe one can do. The OEM of the compressor had told me that the only way to increase the motor run timer is with a new programming done with a laptop. As I was out of work today the co-worker told me he place a screw driver and turned it to the right therefor increasing the run timer. I hoping someone can point me to any PDF or information on how to use this potentiometer slot, and can it even be used without a laptop hooked up to the PLC. Also hoping the coworker did not mess this PLC up. Thanks in advance.
