Help with MSG on CLX
abban
Nov 2010
Monterrey
Hello everybody, this is my first post in this forum, i hope you can help me.
I'm having troubles with messaging with 3 CLX 1756-L63 controllers, all of them should have communication running between them. The problem is that one of them doesn't read the data from the others!, the others can read from this one!.
On this MSG that is not working I get the extended error code 16#204 (unconnected message timeout).
All of them have the same configuration:
Message Type: CIP Data Table Read
Path: Scada, 2, 10.110.12.XX, 1, 0.
I also check the IP configuration on each Ethernet card, and all of them have the same subnetmask and gateway adress
I don't know what else I can try, it's seem like this MSG finds the other PLC, I don't understand what does the error code means on this case.
anyway thanks!
I have a network with 4 PLCs PLC1 is controllogix and PLCs 2-4 are compactlogix and they all need to communicate. The current way I have this...
279
Hello All, This might be a simple question for most of you. I am working on performing some tests on an EIP device through RSLogix 5000. Based...
2,067
Hello all, I'm tasked with getting 2 of our machines to turn on an output in a 3rd machine's plc. I'm halfway there. One plc is on the same DH+...
1,886
Hello Guys, I'm trying to set up a message instruction between two Compact Logix processors that are on the same ethernet network. All I'm...
2,452
Hello! Guys! I finally solved the problem of convert S5 to S7 ! Really thank you for your advice! And then, I have a question about command in...
1,512
