Help with Panelview Pluss 600 password protection
stinkyfive
Aug 2012
over there.
Hello, I have a Panelview Plus 600 running with Micrologix 1400 plc. I would like to protect some of the hmi push buttons with a password, but for the time being I can't see how, .........help!!🤞🏻
Stinky
Hi & welcome to the forum.
Have you read the help files within Studio? They might give you some idea if you can't follow what I have written below...
I would start by adding a new user to the factory talk security system... This is found down the bottom of the explorer window (window on left hand side) under system --> Users & Groups --> Users.
Right click the Users folder to pop-up a menu where you can select the option of creating a new user.
Next step is to add this user to the runtime security tab. This is again found in the explorer window under System--> Runtime Security. Click this tab & look for an icon to add a user.. This icon is located along the top row of icons - it is the icon on the end which is not greyed out.
Once you have added your user you can click on the close button & save changes.
Are you still with me?
Somewhere in the project you at a minimum will need to add a login button, so your user can logon.
Getting back to your HMI buttons that you have existing, I would right click on them & select the animation-->visibility tab.
You can then write an expression something like systemuser="username" to make the HMI button visible once your user has logged on.
Post back if the above is not clear,, or you need further help :)
Can anyone help out with this Panelview Plus Performance Email. I keep getting an "unable to activate connection "smtp-mail.outlook.com". I've...
216
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
283
Ive got an existing panelview plus 1000 with a logic module of 2711P-RP and an assembled pn of 2711P-T10C4D1 running out in the field. Its in an...
1,178
Hi all, we have several identical machines running allen bradley plc's. they are all the same, same bit addresses, timers, counters. same...
1,392
I currently have an issue trying to track down a tag in the PLC. This tag is for a panelview indicator that was custom created. Can someone assist...
1,804
