Help with RSLinx and yellow question marks
danteirurzo
Oct 2022
USA
Hi community!
Before I installed CCW my RSLinx was working fine, but after it, I cannot connect to some PLC's in the network and all the devices appear with a yellow question mark.
I already tried to install all the EDS, upload EDS from the device and still not working.
I contacted rockwell support and they send me this tech article " FactoryTalk Linx (RSLinx Enterprise) Shows Yellow Question Mark for Everything" but I cannot open it because I don't have a tech connect contract.
Could someone help me please telling me a summary of the article or with your advise please?
Thanks very much
In a nutshell . . .
Go to C:\Program Files\Common Files\Rockwell and see if the file named HardwareDatabase.xml is present. If its there, Open it using Notepad or a XML editor.
See if the version of this XML file matches the version of Linx installed by looking at <VersionInfo version>
If it doesn't match, "repair" Linx from the Control Panel after stopping the Linx service.
If you don't have the file, Try to reinstall Linx
If the file is still not there after a reinstall, copy it from another PC that is running the same version, stop the service and copy it over, then restart the service.
Hello all, Some time ago we replaced a client's old Rockwell SCADA with Omron's SCADA. It was our first and so far only time working with Omron...
2,139
Hi, thanks in advance all for reading. I'm automating my lathe and I am using my AB CompactLogix L45 PLC as control. I followed the basic steps...
2,358
Can anyone tell me why i can ping a node (hmi in this case) but RS linx wont see it using the Ethernet/IP driver. My Rockwell software is running...
8,667
Hi guys, Ive got RSlogix emulate 5000 running with a emulated controllogix 5000 series PLC in slot 2, it seems that the rslogix enterprise is...
1,882
Hi there, I have little annoying problem with configuring Alias Topics in RSLinx Classic Gateway. I created two drivers for each PLC in redundant...
2,643
