I can Ping, but i cant see it in RSlinx HELP
gareth_mint
Dec 2010
uk
50
Can anyone tell me why i can ping a node (hmi in this case) but RS linx wont see it using the Ethernet/IP driver.
My Rockwell software is running in a VM with the network adaptor set to NAT.
This normally works for me, but im not sure whats changed.
thanks for any advice
Gareth
I can't explain why it works... I'm sure the more advanced guys on here could.
i just chalk it up to being one of Rockwell's quirky 'features'
I tried that and it works, this confused me more!
thanks for the reply
If browsing Linx with an EtherNet/IP driver returns no results but the Ethernet Linx driver is successful (just like the ordinary CMD/'Ping') is probably because of your particular system topology.
Most likely, your PC's NIC is not located on the same subnet as the target device; EtherNet/IP RSLinx drivers cannot 'hop' on a different network segment (subnet) even if the machine you are using and the network switches are setup to do so.
When the target devices are located on other network segments than the PC's NIC is connected to one would use an Ethenet RSLinx driver in order to establish connectivity.
dmargineau is correct above.
Further to this though, specifically the reason this is happening with your VM is because you are using NAT mode.
Try setting your VM's NIC to bridged mode, and then set your IP in your VM to be on the same network as your HMI, and you will be able to use the Ethernet/IP driver as you would expect.
Always have been able to. What am i doing wrong? I just get and error message (see screenshot) [/URL]
1,988
I have CLX 5561 that has some inputs that are dropping out and I cant figure out why. I have a counter to catch them dropping out and also a timer...
19
6,173
Hi, I am new to ladder logic. I have completed a code in the Xinje PLC XC3-32RT-E for one of the machines I am developing. Currently the program...
30
1,024
Hey guys, the scenario is: I have already completed the drawing package for my system utilizing an A-B 440R-N23126 (Minotaur) safety relay. SoS...
146
Hi all, New here and new all round to PLC`s. We have a servo drive that runs a cross travel beam backwards and forwards. I am having trouble with...
207
