Help with SLC500
sparkytex
Jun 2013
Port Hardy B.C.
354
Hello Guys,
I'm trying to get online with a SLC 500. I've never had issues going online with it before with the current program but now it keeps giving me the same message when I open up the program and click go online, or even if i try to use system comms and upload.
file name "PLC31001_10_05_2018"
The same message appeares as follows:
Filename: No matching file found
Select file to merge for documentation (names, symbols, descriptions, etc)
Processor Name: 31001
It gives me the option to:
Cancel
Create new file
Browse
I'm afraid to create new file as I'm always weary creating or downloading anything new.
Any help getting online with this processor with this program is greatly appreciated.
Thanks,
- Tex
I had a Mechanic in one of the plants I used to service learning PLC and unknown to anyone he changed the processor name on everything he could get on line with from the OEM name to their machine name drove me nuts until I figured out why I had no merge file. I had to change them all back, luckily he was no longer there, unlucky for where ever he went!
LOL... I did that before, wait maybe that was ME :D , oh never mind I changed them back myself after I realised what I did, I ended up making a cheat sheet and hanging it on the wall, it was on a DH+ network with 15 nodes and it was a pain to try and figure out what one was the one you needed
Hello im hoping someone can point me in the right direction. I have a SLC-500 that the program has been erased. I'm being told it will require an...
1,543
im using Slc5/04 one of its 8 channel analog output module 1746-NO8I got defective if i replace it with new one do i have to re-program or...
3,267
I am looking to see if somebody can assist me with a pdf copy of the attached SLC500 RSS file. Thank you Jeff
1,987
I am working on a conversion from a SquareD PLC to a SLC series PLC. I have run across one issue that I can not seem to overcome. The older system...
1,678
Hi Team, require help in getting AB SLC5/04 to talk to Citect 7.2 sp4. via USB 232 convertor using AB_DF1 Driver. RSlinx 2.58 is talking to the...
35
10,776
