Help with timers in GX IEC developer
AndersW
Jan 2010
Sweden
24
Heya
im doing a small program in gx iec developer 7 and havnt really programmed in years so some help with this would be nice
im programming an FX3U and plan connecting it to a beijer E1032 screen once i get that far
Anyway what Im trying to figure out right now is how to have a timer change value from a register using a function block so I can change the value the timer counts up to with the E1032 panel
If anyone would take the time to explain this to me as simple as posible id be very happy
This is a standard timer in GX IEC.
The presetvalue could either be a constant or a registervalue.
The registervalue could be addressed and changed from an operators panel
Thank you so much :D I assume that i can do the same with counters, if I use this as a transition do I need something to reset the timer or will it do that automatically when the setpointtime has been reached?
Sorry for being a bit slow here also havnt had time to play around with it today hopefully ill have time tomorrow but if I understood this right
I'll add a D0 to Preset, do I need to use a M0 as a coil and M1 as status? and then use the M1 in the transition?
ive only used timer_m the past 6 years and there I can use TC0 and TS0 and just use a "cable" to pull it
Hi, I have a project that i have to use a Mitsubishi FX3G with GX WORKS2, wich i never worked with before. I´ve been working with TIA Portal...
3,002
I am an aspiring control systems engineer. I have a lab right now that we use plcs and programs to control what motors do. I am racking my brain...
4,669
I'm programming a PLC in zeliosoft 2 using the FBD mode. I was wondering if anyone knew if it is possible to record the time between two switches...
2,832
Hello im new to plc programming with Omron Cx Programmer I have made a program to trigger timers one after the other and repeat the process...
23
5,662
Hi everyone. Long story short, we are using ladder logic to run an SFC. Due to the nature of an SFC we need about as many timers as we do states...
5,319
