Money4Nothing
Your intel device is not what you want. Its not a PLC, nor is it a device that can be controlled by a PLC output.
Here is a list of PLC input and output modules that can input data or control devices:
http://web4.automationdirect.com/adc/Shopping/Catalog/PLC_Hardware/DirectLogic_05/Discrete_I-z-O
There are links to a spec sheet for each device.
If you want some devices that can be used by PLCs in control applications:
Here is a pressure transducer datasheet. It sends a 4-20 milliAmp current signal to the PLC that is proportional to the amount of pressure that it detects.
http://www.pvl.co.uk/datafaxes/1040%20-%20PS%20transducer.pdf
Here's a datasheet for a panel LED indicator light. A PLC output can turn this light on and off to indicate the status of something in a system.
http://www.dialight.com/pdf/PanelMountIndicators/249-xxxx-37xx-504.pdf
Here's a datasheet for a digital meter that can connect to a PLC analog output. The PLC can transmit a voltage to the meter that's proportional to the value of some parameter to be displayed for a person to see.
http://www.topac.com/DPMpdf/AP200.pdf
