High Speed Counter Compactlogix
dave k
Jan 2011
ny
26
Team,
I have a 1769-L24ER-QBFC1B and I am using the High Speed Counter.
The application is fairly simple. I have a 1024 PPR encoder on a material take up spool that gives me pulses for ribbon distance and speed (rate). I use the pulses to track distance traveled and when the distance is complete I stop the take up motor, do some other functions and then restart. I need to RESET the encoder position to 0 so I can start to measure the distance again.
How do you reset the position:eek:
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
80
i am bench testing a 1734 -VHSC24 Point I/O High Speed counter module, i cannot find any examples of wiring the outputs from the module. does...
1,396
Hello guys, I have created a program where I count the high speed inputs of a flowmeter and create pulses per second to check the flowrate. Next I...
1,792
Hello to all, I don't have to much experience in the PLC. I'm using the Studio 5000 v32.03 We are trying to measure the length of a product, in...
1,139
Does anyone know how to set the output window on-off values on the fly without having to inhibit the module? I could of sworn when I first started...
2,385
