Higher output verison of LP2953 for 4-20ma PSU
kiwisoundguy
May 2011
Glasgow
18
Hello all,
I am after a wee bit of help.
I am looking for a regulator that is similar to a LP2953, but with a much higher output current, for a PSU for a 4-20ma sensor display.
My understanding is that the LP2953 can be configured to 'turn off' or rather snap off when the input voltage is too low to provide the correct output. See page 26 of below link http://sva.ti.com/assets/en/appnotes/f4.pdf
I would like to build a very simple DC (battery powered) PSU (12 - 18v, maybe 24v max input) 12v output @ minimum 800ma - prefer 1a or more.
The reason for having the PSU switch off when the voltage drops, is the sensor attached doesn't behave accurately when the PSU is too low. Rather than have a warning led, I'd prefer if it simply turned off.
Any ideas?
Thanks in advance.
I do not work in the AllenBradley field much, but we ran into an incident that I thought was unusual. Its a 480V vfd. The input current is 59.6...
20
8,512
I am working on a new project and I am just benchtesting the design and components. I have a ControlLogix with a 1756-OF4 Analog output card. I am...
2,602
VFD is not tripping at higher current , resulting in motor failure . VFD Model : Make - KEB Type - H6- 10H6BBBB-21B0
518
Hey everyone, Trying to install FTView ME 9.00 on a new laptop, no existing FTView install. Every time the installer gets to ~55%, it fails and...
2,423
Hi everyone, we have a working part rejector already. The issue is the new encoder went from 100ppr to 1024ppr. Hardware is compactlogix...
1,931
