Highest Value
Yes good catch on the Scaled Max. I knew it should have been 10. I have been moving so many numbers around I must have left it incorrect.
Where should I be capturing the data from my input card?
What channel is the input connected to?
If channel zero ( first channel ) then I:5.0. Also use that address for the SCP instructions input.
folks i have 104 lamps that record their hours on the panelview, so i need to get the highest hour value of these lamps data data type is...
26
5,590
Hello Currently have a project in which I have to find the highest value in a dint array. Once the highest value is found I will have to move...
20
11,580
This is a Citect SCADA question I have Six variables of type REAL (Float) to compare and determine (identify) which variable has the highest...
1,445
Plc: RX3i Cpu: CPE305 I want to search a range of real registers for highest value. The range is R1050 to R1525. I thought it would be an array...
1,631
I am trying to find a function block to determine the second highest value ( i need the second highest value out of 16 thermocouple temperatures)...
2,574
