Hilscher RIF 1769-DPM
tgoulding
Jan 2005
84
Working on a project with an existing Allen-Bradley CompactLogix PLC containing a Hilscher RIF 1769-DPM Profibus card which is the master. We need to add an additional node to the existing network.
As we don't have access to the original configuration file for the RIF 1769-DPM, is it possible to upload this configuration add new slave and then download amended configuration. Which software should be used 'Prosoft.fdt' or 'Sycon.net', a little confused from the information I've read as to whose card it is.
If the original configuration file was created in 'Sycon.net' is this the software to be used or can it be read with 'Prosoft.fdt'.
Our main area of interest is to upload the configuration change it for the additional node. Any help on this would be appreciated.
Does anyone use or have experience with the Hilscher NT 100-RE-DN Gateway? Tech support on Hilscher website for the North America region is two...
20
3,426
Has anyone got any experience with Ethernet-mpi IBHlink & tia portal 14 or newer I have it working fine in simatic manager but in tia, although...
1,924
Does anyone have experience with the Hilsher NL50-MPI Ethernet to Profibus adapter with Simotion Scout? I am using VMWare to run Windows XP with...
3,780
I'm using a Controllogix 1769-L24ER-QBFC1B and trying to setup a Generic Ethernet Module to communicate to a Hilsher NT50 ethernet I/P to...
6,744
First post to the forum. Just needed some ideas of what is happening.:scratch: We are running a Siemen PLC S7-300 in conjunction with a Window...
4,423
