CLX Generic Ethernet Module - Hilscher NT50 Comms
rdombek778899
Nov 2012
Sherwood, Oregon
I'm using a Controllogix 1769-L24ER-QBFC1B and trying to setup a Generic Ethernet Module to communicate to a Hilsher NT50 ethernet I/P to Profibus-DP adapter. I've entered the Assembly instances and sizes according to the Hilscher document, but am getting the following Module fault in RSLogix5000 in the 'Connection' tab for the module:
[Code 16#0128] Connection Request Error: Invalid input size
Not sure where to go from here. Any suggestions/help would be greatly appreciated. o_O
I deleted the module and used Hilscher's EDS file, then created a new module where I found the Hilscher NT50 in the list. In the configuration for the module I selected Disable keying and entered just the number of input/output sizes 88/84 according to Hilscher's document. They did specify Assembly Instances of 101 (input), 100 (output) and 102 (configuration), but there is no where to enter this info....However, when I downloaded, the module came up as "Running", so I believe I'm good to go so far. I don't get the yellow triangle over the module anymore while online.
Depending on the version number of you RSLogix5000 you may be able to import the EDS file and use it. Hilscher has a White paper specifically telling you to add 4 bytes on the input for the V20.3 and older Versions of RSLogix5000. You are always able to call us for support on 630-505-5301 to assist you in configuring our devices or any other questions. Please do call.
Hi, When using the generic ethernet module instead of the AOP, will the EDS-file still be necessary? I've seen some programs where I don't...
4,226
I have added a Generic Ethernet Module to a Control Logix processor. Where can I find the fault code in the Control Logix that shows I have lost...
4,210
Hi All Is there such a card as generic sercos card for control logix. I think I remember someone telling me about it. If so has anyone used...
2,432
Controller: 1756-L84E v.35 Prosoft MVI56E-MNETC for ModbusTCP/IP I'm having an issue with some of my write commands. The write command that...
196
I have several Avery scale units and they are configured as Generic Ethernet modules, and I am actually reading the data fine for the weight...
422
