Is EDS-file necessary for Generic Ethernet Module, CLX
spaderkung
Aug 2007
South Sweden
389
When using the generic ethernet module instead of the AOP, will the EDS-file still be necessary? I've seen some programs where I don't understand the use of the generic module when there are easily available AOP.
But, in our case it is also sold programming licenses for Studio 5000 to be installed by the customer themselves on a future PC. Then if we use AOP we must supply them with all the EDS as well. Will the use of generic ethernet module eliminate the need for additional installs on the client PC?
BR
All modules need the proper EDS file for its hardware, even people making "generic" modules will have a proper EDS file for it, chech with that manufacturer.
It's the generic ethernet module that is selectable from studio 5000. Even if an eds is required I don't see why, because the ethernet/ip protocol is implemented in the partner. There is no communication to the hardware of the partner, just what's exposed.
If the object is in the Studio 5000 I/O tree as a Generic Ethernet Module then no EDS file or AOP is required to be registered or installed, and there will be no lost functionality in the project.
When I do multi-vendor controller projects, I consolidate all the EDS files and AOPs that I have used, and deliver them along with all the project configuration files.
Hey y'all!! I'm looking for an old EDS file, GSE 560. I can't find them anywhere. It is for a GSE560 display on a DeviceNet network, with...
76
Hello, This product that I have the 1790D-T8BV8B is discontinued, does anyone have the EDS file for it? I wonder if TechConnect will have this...
188
Hello Friends We have 10 Powerfocus 4000 with DeviceNet, We need to backup the configuration, the Powerfocus is detected but as unrecognized...
110
Hi everyone: I went to AB.com, found only firmware, no EDs file showing up. i took a pix of device properties of RSLinx. Thanks
128
Hi all. Please can anyone assist me with a Devicenet EDS File or link for a Numatics G2-2 solenoid valve bank. Need to do configuration on a...
712
