hmi recommendations
PC based = Ignition
Hardware based = Red Lion
I have one customer with IWS and although the original designer made a mess of it, it works well and I was able to get excellent help when i cleaned up a little bit of it.
Checkout Beijer IX.
Compile for PC & CE HMI's. Roll your own bespoke stuff in c# (very powerful). Best bang for the buck in my opinion.
Maple System. I'm amazed at the people that don't these HMI screens.
AFAICT, Maple Systems is nothing but rebranded stuff. Their larger HMIs are Weintek, and their newer HMCs are Renu. I made the mistake of buying HMCs from them (which aren't good to begin with), and tech support knew so little about them a project was delayed for months. When we finally found out we could go to Renu directly, the issue was resolved in a day.
Also, +1 for:
Red Lion (really nice)
IDEC (okay, good value)
Used the Maples (both Weintek and Renu), can only recommend the Weintek. Good value, but not very polished.
If we can afford to go rolls royce we use Red Lion, otherwise IDEC is the default.
Anyone have an opinion for ez automation?
Prices are low, but so is Automation Direct.
The HMI software is basic, covers most needs. So is AutomationDirect.
If you need a basic HMI, will engineer once, and ship out a 100 each year then either of those seem fine.
Need more umph? Red Lion is very good and easy to learn.
Need every feature imaginable? Proface is also good, but difficult to learn/use.
Want modern programming at any price? Beijer.
Hello, I'm working on a machine retrofit project, and am looking for recommendations for HMI/SCADA software. I've used C-More and Horner HMIs...
1,932
Does anyone know of a rugged PC based HMI that is pre-fabbed for installation inside heavy equipment? I have seen them in earthmovers/mining...
2,314
Hello, I am looking to order an electrical panel to add to the front of the machine, which will have HMI, e-stop, and e-return. Something similar...
2,640
How is the boot time on the PANELVIEW 800 HMI 2711R-T4T? I am familiar with the old Panel View Component AB 2711C-T4T and the boot time of over a...
6,406
My company is currently using Citectscada for our HMI/alarming/historian, which is a program that I haven't had much exposure to. I was given the...
3,000
