HMI siemens with micrologix 1100
For a KTP400 2nd Generation:
Set the Ethernet port to be connected to a LAN with an IP that can reach the ML1100's IP.
In the connection setup, add a new connection, chose Allen Bradley/Ethernet/IP as the protocol. CPU type =Micrologix. IP address = IP of the ML1100. Communication path = 1,0.
Then start adding Tags.
I believe that is all.
HAve a error
I have a error. conexion with controller Micrologix 1100 (192.168.1.12) stopped
Good Morning, How can I conect with ethernet Siemens KTP400 with Micrologix 1100 allen bradley
1,585
Buona sera, Ho dei problemi nell' interfacciare PLC S5 con HMI 2a Gen. Siemens (ad esempio KTP400) tramite IBH Link S5++. il mio obbiettivo è solo...
106
Hello colleagues, On a Siemens Multi panel (MP 377 12") of a machine (S7-300) at a customer's site, some parameters need to be changed that have...
318
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,463
Good day, May I ask, what do I need to perform MIGRATION of HMI program from Siemens MP277 10" Touch hmi to TP1200. I already have WinCC Flexible...
169
