HMI with a XY graph function
Edmhydraulics
Apr 2014
Beaumont
173
Hey all, I have a project where a customer wants to plot 2 variables on a graph, flow rate and speed. I can easily program a graph on an HMI with one variable against time with time being the X-Axis on the bottom and flowrate being on the Y-axis.
What I would like is instead of time on the X-Axis that I can use an variable such as speed.
I have produced graphs like this with Excel, but are there HMI's that can do this. I have used quite a few Red Lion Graphites with Crimson 3, but I dont think you can do it with Crimson.
Thanks.
Yes you can, when you make a scatter plot in Crimson you specify arrays for the X and Y axes. So you can basically plot anything against anything, it's quite versatile. I believe you can have up to 4 overlays on one graph.
Nice looking XY plot available from Beijer X2 Base HMI
Red Lion has an XY PLot but you have to add a scale for the Y axis from their legacy tools. I can't find a horizontal scale tool to use. Overall, the plot looks very dull.
Beijer X2 Base HMI's have a very nice XY Plot with auto scaling X and Y axis. The HMI is almost half the cost of a Red Lion HMI CM3000 and looks a lot more modern in my opinion... The simulator in iX Developer works great - Red Lion has removed their simulator since it doesn't work! Don't know about reliability between the two - we will test them side by side.
AB's Panelviews are also capable with an active X (supplied with FTView ME). Example code with UDTs that you populate are provided also. Works pretty good except its slow if there is a lot of data and the screen is displayed the first time - updates are fast.
Hi Guys, I'm designing an HMI application for a Gas metering Plant, Right now I'm stuck at a point where I have to make a screen for displaying...
26
7,943
This is my first attempt to use AdvancedHMI. Working with an Omron CP1L and the Serial FINS driver. I was very quickly able to set up a test...
2,112
I have 50 points stored in my plc that I want to graph on the screen. Do any popular HMI's come with a good graph object? I tried using an...
3,545
Hi Guys! I'm doing a small setup where I plan to show some motor current data as a real time graph in AdvancedHMI. I have a CompactLogix PLC...
2,951
Good afternoon guys. Thanks to all for the really good info I have gotten on the site thus far. Could not believe how many ways there are to do...
4,533
