Hoe to determine port address for Telnet in win 7?
krakenfan69
Nov 2011
Alberta
229
Hi guys. I need to Telnet into a device to enable a feature. I turned on Telnet in Win 7 and can get it running but when I type the command>
o 192.168.02.13 it wants a port number. I don't know how to determine the port number my ethernet adapter is on. Can anyone explain to me how to locate it?
UPDATE: I'm an idiot. I needed to type the port address of the device I was trying to connect to. In this case 10000.
so from the cmd prompt I type>
telnet 192.168.20.13 10000
and I'm in. For reference purposes this is to connect to a Datalink Technologies GW-1000 ABEIP DH+ to Ethernet converter.
Maybe this will help someone in the future.
Thanks,
Kraken Fan #69
Did you question and answer by yourself?
If this happens to me, I'd rather delete the post...
Thanks for the tips, m8.
I was put on this earth as a shining example of what NOT to do for others. Just doing my part.
Cheers
Kraken Fan #69
Hi everyone; I have an pv 550 touch, and I want to see him on rslings, I have a usb to serial converter and 1747-uic, my pv has 2 ports DF1...
4,621
Hello, i am a beginner with a Siemens Logo 8 PLC. I would determine the direction of an object if it passes a whole cycle of 2 input sensors. See...
196
Hi all, Just looking through the CIP_AXIS_DRIVE data type in a Logix controller to look for something that can tell me whether the current...
1,073
I'm currently working on an MES interface PLC which passes around a whole bunch of strings. A lot of these strings are really just to allow for an...
1,123
I don't use AB much these days, and any installs I've done in years past have been setup by myself from scratch, so I've always known what...
2,087
