Honeywell Multitrend SX - factory password?
sandwich
Apr 2007
Winnipeg
Got locked out of the setup. Need an administrator to unlock the user account but its the administrator account thats locked. No way to get back in? Any factory passwords or procedures out there to reset the account?
To my knowledge, there is no backdoor password for the X series.
You need to call the factory help line (in the US it is 800 423-9883, not sure about Canada) and provide them with the internal serial number of the recorder, a 6 or 7 digit number starting with 8: 8xxxxxxx
The internal serial number is on the paper tag above the CE logo mark. It's also listed on one of the status pages
menu > status > system > general > serial number
Using the internal serial # and the date, they can generate a temporary password for one day's use, assuming the recorder's clock is the same date as the day you call in. It's worth checking what date the recorder thinks it is, in case someone missed daylight savings time change last time around. I assume that they can adjust the password for whatever date they're given.
I can't recall whether you get a user name or not to use with the temporary password.
Once you log in, regular configuration menu items are not available, only edit > passwords, if I recall properly.
IMPORTANT: Do not "reset passwords"
"Reset passwords" wipes out all user names, passwords and policies and you have to start over with any or all security (password) settings.
Temporary access allows you to either reset an individual user account or to add a new admin user.
My notes indicate that I had a problem trying to "reset" an administrator account and that I ended up creating a 2nd and 3rd user accounts with administrative access.
Dan
This is more of a knowledge base post as opposed to a question. Hopefully somebody can learn from my issue. We've recently installed a Honeywell...
1,974
I am trying to use the scripting functions in a Honeywell Multitrend SX to set digital outputs based on digital input status. Scripting is...
1,979
So...we bought this equipment to use it specifically for TUS (temperature uniformity survey). We ran test surveys from 30 mins to 180 mins...
3,184
Hi, I've got a Honeywell Multitrend SX paperless recorder that I'm using as a Modbus Master device to poll another I/O device for some analog...
5,227
Hi Anybody knows how to enter Honeywell HMI config menu. I need to change date and time of HMI. HMI series: Honeywell HCi series
119
