Honeywell PLC
Honeywell PLCs
1980-1990's: IPC620 (Klockner-Moeller IPC62) Long since obsolete, no support; primarily used with their S9000 multiloop thermal controller
2000's: MasterLogic. a private labeled Korean
https://process.honeywell.com/us/en...y-systems/modular-controllers/masterlogic-plc
2010-ish to present: ControlEdge PLC
https://process.honeywell.com/us/en...y-systems/modular-controllers/controledge-plc
2000- present: HC-900; not a PLC but a Hybrid Controller/PAC
https://process.honeywell.com/conte...ns/ControlEdge-HC900-technical informatio.pdf
ControlEdge PLC and HC900 share rack/I/O hardware.
Honeywell made a process controller CPU (not PLC controller CPU0, the C200, which Allen Bradley private labeled. Honeywell sold the C200 through their DCS channel (which is heavily gated with limited access).
The C200's functional replacement is the UOC controller, which shares the ControlEdge PLC/HC900 hardware platform.
Hey guys, I am trying to pull the ladder logic out of some ancient Honeywell S9000 PLCs, but I can't find the software anywhere (google search...
4,886
Hello, friends. I've programmed a ControlEdge 900 PLC (900CP1-0200) and I now have to make an HMI application for a 900 Control Station...
2,046
We are currently considering switching our HVAC control from Honeywell to AB. I was tasked with tracking down all of the devices to determine...
1,513
Hi everyone, I have been tasked with the job of setting up FT View SE SCADA for a compact logix PLC. There are also a few points that need read by...
2,632
Hi guys Just wondering if anyone has succesfully read barcode data from these barcode scanners to a plc via rs232 or rs485? If so do you guys have...
1,463
