Reading Data from Honeywell PLC to FT View SE
Neidin
May 2017
Northern Ireland
Hi everyone, I have been tasked with the job of setting up FT View SE SCADA for a compact logix PLC. There are also a few points that need read by the SCADA from a Honeywell PLC. I have been supplied with Factory Talk Gateway to do this but am having trouble setting up a connection to the Honeywell PLC and don't see much info about on how to do this.
I have used the Gateway Configuration to connect to my SCADA application but thats as far as I can get.
Can anyone offer me some advice on how to go about this?
Any information would be greatly appreciated!!
What Honeywell PLC do you have? If it's a 620 system what modules do you have in the CPU rack?
172
Hello! New to the forum and new to PLCs in general. We have an ABB AC500 PLC (circa 2012?) and we are using CoDeSys (version 2.something). We're...
649
Hello Ken Roach, Thank you for your quick reply , As informed earlier i want to read P&F Sensor data on Micrologic 1400 series B using MSG...
17
5,818
Anyone experience of working with these modules and interrogating status of an I/O port? The modules can throw up a red LED indicator to say an...
1,094
Hello, I have a Micro850 PLC that has 5 2080-IF4 plug-in modules attached. Each of these modules are programmed to read 4-20 mA output signals...
2,329
