How do I Compare Programs
iadapt
May 2012
Indiana
177
I am trying to update a program by going from V20 in RSLogix 5000 to V24 in Studio 5000. I am going to add some additional logic as well. How could I smoothly compare the two programs logic/tags?
I have downloaded the .csv files of the tags for both programs so far.
Any ideas or procedures you guys use?
Sure, I use the Logix Designer Compare tool. Should come w/ your Studio install, if it didn't install it is on the dvds.
I would first do a compare of your original V20 program and the V24 program before adding any additional tags/logic. Make sure nothing unexpected changed.
Then you can add whatever else you want and do additional compares.
is there a way to open a compact logix plc program and then compare that to the program that is actually running in the plc Thanks
1,077
Can anyone tell me how to compare 2 offline programs so that I can see what differences there are between the 2 programs. This is quite easy for...
1,811
It has been a while since I have done this:hmmm:. Any help would be greatly appreciated!!
5,393
Hi again, need some more help. I am trying to compare 2 programs using rslogix 5000. I know you can do this with logix 5 and 500. Am i missing...
8,399
I'm probably going to need to modify the ProTool program for a TP170B in the near future. Looking at the program as stored in the copy of the...
7,091
