How Do I get Control Logix Consumed Tag Status
sikoraj
Jan 2008
Edson
I have 3 Control logix L55 processors that communicate via ControlNet using some produced and consumed bit words. I have seen a case where one of the processors major faulted and the other processors did not know it and the bits being consumed stayed in last state. I have found AB documentation about looking at the Connection Status member of a tag structure but it does not really explain or show a example of this structure. Imagine AB documentation not really that great? ;(
Anyone with a example or is there a better way to monitor if a processor is still up and working??
I monitor PLC status with a handshake methodology. You should be able to do the same with your setup.
I could give you a very detailed explanation of the Module Status object, which I understand in detail and use routinely.
But my documentation isn't that great.
Hello and thank you for taking the time to view my post! First of all, I've attached an image as reference. What I am trying to accomplish is...
4,368
Can you produce and consume bits from a SLC500 to RSlogix 5000? I am needing to get a flame on from 500 and interlock some equipment on the 5000...
3,041
I am having trouble with getting no control of my analog output signal. I am using the SCL function block to control my analog output. The logic...
273
hi all, i have a plc i need to get info from for a site im working on: I have a 1764 Micro Logix 1500 LSP Series C (See Attached Image) im...
389
I currently have a weird issue involving Ethernet IP communication between a ABB CI873 (EthernetIP Module) and a 1756-L83ES. The Layout is as...
793
