How do I get rid of this message
LowRange
Jun 2016
Omaha
52
"do you want to replace the terminal's current communication configuration with the application's communication configuration"
I have: Panel View Plus 6 400 and Factorytalk ME.
I understand that I need to select 'yes' to this question to give the application's communication configuration to the PVP+ but why does it keep asking even after the PVP+ has the communication configuration? I'd understand if the two communication configurations did not match but the settings of the application and that of the terminal match exactly.
The transfer utility compares only the filenames and not the communication configuration. So you have to live with that annoying message.
Thinking a little more, there'are some checkboxes in the transfer utility. One is for running the application when the PV is starting up, and other one is for replacing the communications. You can use those checkboxes to get rid of the message.
There are similar checkboxes inside the PV settings. Follow the images of this post:
http://www.plctalk.net/qanda/showpost.php?p=703935&postcount=9
In the final image, click on Run options.
Hello, I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up...
89
Hi All, I'm keep getting double quotes in between selections rather than the beginning and the end. Here's the script and please help to find...
804
Hi all, I'm trying to visualize an array of type structure using Datagrid control. Im assigning the array to the Model property of the Datagrid...
660
Greeting experts! We have a new machine we just built. It is equipped with regenerative drives. The machine uses Beckhoff controls (PLC and...
1,088
hi every one am controling the hbs86h driver with s7-1200 plc the drive have the PEND+/PEND- which indicates that the stepper reached it's...
868
