How do you handle a service call for ControlLogix w/ unknown Firmware Revision
That is not correct - all versions from 10 upwards will run on Windows 7.
I have versions 10, 11, 12, 13, 15, 16, 17, 18, 19, and 20 of RSLogix5000 running quite happily on W7, as per the picture.
I occasionally have to use all versions, so have tested them all, no problems.
Note that not all versions support all controller models.
Yes but when the firmware on the controller is V11 then, of course, the controller supports V11. It can *run* on Win7, but going online with a controller/opening the project was a different story, and this was with any project, even one I created myself from the VM, over different install mediums, different formats, etc. Even Rockwell tech support said it just wasn't going to work (though I can't remember their reason, it has been a couple years). I would LOVE to see it work.
I am working on a project using AB PLCs and PanelView HMIs. There is a desire to allow control loop setpoints to be provided through the HMI or...
3,689
I've used Banner for RTD's, thermocouples and 4-20's but not for discretes. I called the factory to find out whether either PNP or NPN wiring...
1,478
The hole size to mount a through door handle is 65mm to 70mm. I can not find a punch that will work in Stainless Steel. What are you using to...
1,137
Hi; We have below mentioned softwares for PLCs, PVs drives etc. I want to ask what is the best practice to handle these softwares, should we...
2,985
When you're doing a project, especially small ones how do you handle designing the emergency stop circuit? It's my understanding that the...
2,311
