daevy
When you've programmed one FB with the Local variables on top of the FB ( IN/out/Stat/temp) . (SIEMENS S7, Version 5.3)
And you've put your input outputs, example FB1,DB1
FB2,DB2; FB3,DB3.
When there is somthing wrong in the FB2 and you want visualize it with the wright inputs and outputs you've hung at that FB2.
When I Click on the block and monitor it. It uses the inputs from the other FB's. I know You can install a Path: First OB1, than FC2 and then look at FB2. But how do I do that??
FB2,DB2; FB3,DB3.
