desa
Good day. I encountered a problem when calibrating a channel on the IF16H module. The module is located in the local backplane along with the 1756-L73, not a single channel of the module is connected. When I try to set 20mA on channel 3 with a calibrator (YOKOGAWA GA71), the channel goes into error (with a value of 20.58mA), when I set 19mA, the channel shows 20mA. This is not the case with other channels. I can’t go through calibration in the module settings, because the channel cannot receive 20mA, the channel simply goes into error due to exceeding the upper limit.
Thanks for answers.
Thanks for answers.
