wwh1323 Member W Join Date Oct 2023 Location seoul Posts 1 Oct 26, 2023 #1 Siemens s7-1200 is set to 102 as the default port, is there a way to change it to another port?
Puddle Member P Join Date Mar 2022 Location UK - The Norf Posts 333 Oct 26, 2023 #2 Are you trying to use it for modbus TCP? If you use the MB_CLIENT block one of the inputs (CONNECT) requires a tag using the data type TCON_IP_v4 and some of the values specified there are local and remote ports.
mk42 Lifetime Supporting Member M Join Date Jun 2013 Location MI Posts 3,291 Oct 26, 2023 #3 if you're talking about Portal/ connections, then port 102 is fixed, no changes are possible in the PLC or in Portal. What are you trying to do, NAPT?
