How to connect to Siemens S7-200
If you put the PLC in the program mode the default comm settings will be applied to all the ports regardless what they are set to by the programmer. This only applies while in the program mode though.
Try this with your cable using the default settings in the PC/PG manager and see if you can get connected.
I forgot to mention that when I power on my PLC the SF red lamp is on and the run lamp is not turned on. What does SF mean??? Could that be preventing the connection of the PLC???
Ron Brown, What do you mean by putting it in Program mode? and how do I do that?
LOL... small detail, SF = System Fault
Buy another PLC and replace it
I never thought the SF lamp could be the problem preventing me from connecting to it as I already have machines that are working fine and the SF lamp in their CPUs is on and the communication to the drive is working fine as well. Plus, I have recently unboxed that PLC, so it's brand new and never been used by anyone before.
I have never had a 200 with a SF and it still be in working order... there are other Siemens that will run with a fault
You can use a 'wipe out' program to recover some issues (like password) but you still need to be able to communicate to it
If the SF is on and you can not communicate to it then its a bad CPU (IMO)
If its a new CPU send it back and have them replace it
Hi Complete newcomer to S7 so go easy on me... Siemens S7: What cable do I need to connect S7-1200 PLC to HMI? The touch screen is one of these...
2,611
Hello, I am very new to Siemens but have been doing AB for many years. I don't have the information I probably need but here's the story. I have...
1,148
Hello; i'm having some troubles with a com test i'm handling. i have another end for it, but for now i would like to have : M241 in io_scanning...
3,489
Had an issue with the machine cutting stopping in the middle of auto running. So I go to the cabinet to plug up to the plc and well both of the...
1,478
Dear experts, I can't connect to Siemens s7 200, I have Siemens ppi cable but I don't have serial port on my pc so I used serial to usb converter...
4,545
