HOW TO DO A RESET? INSTRUCTION "SUS"?
nesppi
Oct 2006
madrid
35
Hi everybody!
I am programming a SLC 500/03 with the RSLogix 500.
My system needs a reset, so when it is pushed the outputs have to be reseted. I have tryed with the "SUS" instruction, but it doesn´t work..
Does anyone know the best way of introducing a reset button in a system?
Thanks in advance,
Greetings
nesppi said:
Hi everybody!
Thanks in advance,
Greetings
Reset means to turn off the outputs?
Yes, but also to stop the subrutines that are being executed...
I can do a MOV instruction with "0" to the outputs..
But, do you know if there is an instruction?
Or, do you know why the suspend instruction is not working?
thanks
thanks
No other special Inst for Inhibiting the output But you try Inhibiting the slot by reseting the status file bits if your output modules is in local rack
And do you know if there is some bit in the state file which is used to reset the plc directly? I mean, is there any way of reseting the plc, without erasing the memory, of course!
thanks
thanks
why want you to do so
Place your program in a seperate ladder file. Program the jump to subroutine to become disabled when you press your reset button.
and then fll 0 to all your outputs.
Ok, I have tryed this and the outputs are set to '0'. The problem is... if the plc is blocked? How can you restart it? This is the reason to introduce the reset button in the system.. to restart from the button.. that is, that the plc recognize the hardware, etc, all the operations that it does before running the program..
If you use the seperate subroutine the PLC is still scanning
the main ladder file. Your subroutine will no longer be scanned
while your button is held in. and at the same time zero fill your
output datatable. Is there anything else that needs to happen
during this reset?
This code is working as expected, but it looks a bit clumsy w.r.t. setting of "Laser1 PASS". Is there a neater way (different instruction) I...
28
2,795
Hello there, I'm working on adding a historian, of sorts, to a PLC project where I'd like the data that is being stored to be reset on a certain...
4,155
So I have timers in an add-on instruction that work perfect, however I want to change the preset values in all of the instances at once (about 45...
2,893
Hello fellows, I'm having trouble with this program I created. In this program I need the total count in Rung 5 to update every 30s. I added a...
2,119
Hi everybody! Im meet a problem with reset instructions. I must reset about 200 contactscontinues from m10 to m210, this is my program: ...
1,623
