How to download a new program to PLC5/40
wilsonzhu
Jan 2008
vancouver
278
I have a plc5/40e is running a different project's program, now I try to download a different project's program. but it tell me that" cannot get connected to online processor!, DiagnosticStatus failed:Sts=0x02 Link layer Timed out(NoReply) or Received a NAK". but CH0 of plc5/40E is connected by rslinx. pls help.
Use RSLinx to browse to the processor and ensure that the same browse path is used when you attempt to downlowd.
From within RSLogix5 you should be able to find a Who Active...Go Online option, and from there browse to the PLC and then hit the download button.
The problem is probably that the offline file communications settigns are not the same as the actual PLC.
Pay close attention to any warnings you get about changing channel settings and choose carefully whether or not to apply those changes.
Paul
if the advice from my distinguished colleague OkiePC doesn't work for your particular system, try opening the "new file" in RSLogix5 - and then look under the "Controller Properties" area of the project tree ... go to the "Controller Communications" tab and try setting the download path there ... that approach works best for some systems ...
I downloaded a new program to a plc 5/40e just last Thursday. Let me clarify just a tiny bit what Okie said. Under the Comms pulldown menu select System Comms. You will see just about the same screen that you get if you selected Who Active, except that this screen will provide you with the download option. Find you r processor in the tree, highlight it ,and then hit the download button.
I always like to open up RSLinx and verify that I can establish my connection to the processor before I ever open RSLogix. This is a good practice in an environment such as mine where you must regularly connect to a wide variety of PLCs.
Electrically_Bound said:
... Let me clarify just a tiny bit what Okie said. Under the Comms pulldown menu select System Comms. You will see just about the same screen that you get if you selected Who Active, except that this screen will provide you with the download option. Find you r processor in the tree, highlight it ,and then hit the download button.
Thank you sir!
For filling in the specifics
I replied on my out the door from home this morning (on a hunch about the most common cause) with no access to those important steps...
Paul
dear all, I have question, i realy need to help from everyone. Which cable I can use for upload/download program from PLC5/20 to Computer...
2,144
Dear Messes, I had a stupid question about downloading program to the PLC5/25 and every time I tried to download program to EPROM, it keeps on...
2,355
I have a PLC5/30 at home that I am playing/learning with. I have exhausted my enthusiam to try to download a new program (from work) into the...
27
10,584
Hi, New to the forum. I have an old machine I am working on that is using aA172SHCPUN. I want to capture the program in case I need to reload...
22
2,073
Got a problem on an install this weekend I'm hoping someone can help out on. I'm upgrading an old system with a SLC5/04 and Panelview 600...
1,138
