How to download Jetter D-CPU PLC
Jan 2021
PA
Hello all,
I have an old Jetter Delta CPU (D-CPU) PLC. The PLC just died (No light on the RUN, or Error). I replaced the failure PLC with the spare same model PLC. I have an offline file but I don't know the proper way to download. I managed to download the file using Serial connection but the PLC did not return to the correct state (could not log in, no recipes......).
Is it possible to restore the power on the failure PLC?
Please let me know the proper procedure to download the code to the PLC
Thanks you
Loc
Welcome to the forum!
It's been years' since I attempted a Jetter download, but from memory, it wasn't easy. Also, I think the offline file we had didn't contain everything we needed, similar to your situation.
What software are you using?
I was using SymPAS running in DosBox.
We had issues getting remote IO slaves talking.
Thank you Patrick for replying.
I use JetSym software. How do I know if the offline file contains everything that i need?
You're welcome.
OK so if the offline file doesn't have everything, then you need to upload from the old PLC. So you need to send this for electronic repair to restore the power.
I would, in the meantime, try downloading every option. From memory, you have to individually transfer several parts.
Like I said our issue was with remote IO.
You might find the following useful to check your slave IO connections are OK.
Hello, i've been at this for months now, i tried creating accounts on the aveva website but it seems to never approve my accounts or at least when...
55
Hey guys, I have to take an upload of a program on an S71200 PLC to change a hardware config option and then redownload the program with this...
111
Hi everyone, I got a Parker HMI, CTC PA2. I tried to download program to it but it froze in the process and could not finalize. Now, when I try to...
44
I am new In a CCW and as a beginner I am trying to learn programming but i am noticing that my CCW software is taking around 1 minute to download...
108
Hello all, I'm trying to use the Logix Designer SDK to upload and download a single ACD to many controllers. I got this to work fine copying...
71
