How to edit Siemens S7 instance DB?
richxie
Jan 2007
Ontario
31
Hi everyone,
A customer has a S7-300 program, but all written in German. I am trying to translate it to English. But I found those in instance DBs do not allow me to change. Does any know how to edit them?
Thanks,
Find out the Function block that the instance Data block is assigned to i.e FB2,DB2 and then change the text within the declaration area of the Function Block, This is located in the top section of the FBD/LAD/STL Editor below the icons. Watch out for possible timestamp errors though!
Hope this helps
Steve
STL??? said:
Hope this helps
Steve
I think I tried it. However it doesn't allow me to change. Here is the screenshot:
I opened the FB. But I just noticed that these tags that I can not change are nested under Interface\Stat. From there it has its own IN, Out, IN_out and Stat.
Just to make sure, does your Simatic manager look something like below and you don't have the little padlocks on the function block in question ?
You have drilled down too deeply. The LHF_01 items are other function blocks which have been declared in this function blocks interface (something called multiple instance function blocks which allows all the function blocks to share the same instance DB). You can change names with the little tag by them but not those underneath with a circled grey block. Click on the STAT section and the number of the function block will be shown.
I need some clarification about uploading the HMI file from a Siemens MP277 to edit it in WinCC. Although the machine manufacturer is no longer in...
1,362
Hi, I need to make a change in the Hardware Configuration of a Siemens CPU315-2 2PN/DP. But I'm not able to download the modified configuration...
2,029
Hi all, problem is this: Our man in china has made some changes to an old S5 program, and needs to update the operator panel OP20 accordingly...
7,223
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
149
Searching edit zones within all routines and other criteria still says no results found, yet I still have the "edits present" indicator at the...
259
