How to make a profibus network in TIA portal
dingomex3
Mar 2012
mexico
33
Hi, good morning, it's my first time working on a project with Siemens, I've always worked with Rockwell and from siemens I only know the s7-200. I have to make a profibus network with master s7-1500 and Rockwell starter slaves. Someone who can help me or can pass me some tutorial that will help me to do this or some document would be appreciated.
Install the gsd files for the Rockwell devices using Options>Manage GSD files.
In Network view drag the Rockwell device from the h/w catalog.
Right click on the CPU profibus connector (purple square) and and a new master system.
Right click on the Rockwell slave Profibus connector and Assign to new master. Select the master network you created for the CPU.
Hi, I have a doubt about the system architecture shows below: could two master devices install in same profibus network?
2,657
My Siemens Step 7 education progressed today. I'm getting more familiar with how it all works, but at the end of the day I got stuck trying to...
1,028
Hi, I'm retrofitting an Anybus-X Gateway as a Profibus Master on an existing Profibus segment. I'm wondering if this needs to be the last device...
1,232
Dear Superiors,📚:wizard: I'm new for s7-300 and yaskawa v1000 drives communication via profibus. My aim is to find how to run the drive or...
1,786
Good day, I have a problem regarding the configuration and commissioning of a profibus network where the master will be an S7-1500 PLC and several...
1,811
