How To Read Microsoft Access Data Into WinCC???
Jack Schit
Oct 2009
England
35
Hi All,
I'm trying to read some data from a Microsoft Access database into a WinCC V7.0 project. Initially, I've trying to do this using Kepware OPC software but I'm not getting very far (I can't get Kepware to see the Access database)
I have never tried this before and now I'm not sure that this is best way to approach it so was hoping someone could point me into the right direction.
Jack
I do not know if it will work with WinCC, but with WinCC flexible I do it in a script.
I create a ADO connection and use that to call a stored query that I create in the Access database, or you could write the query in your script and parse it to the database.
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
163
Is there a way to use the FAL instruction to do +=2 instead of +=1? I have an array that is organized with alternating "data" and "flag" values...
127
Hi everyone i have a customer, who wants to show an alarm on the machine, if the I/O forces are enabled and set, on at ControlLogix L81E with...
266
Hi Iam using monitouch hmi(V9 soft) with omron plc cj2m (CX programmer). In this I want to read a data from hmi to plc. The data was like...
103
Hi everyone. Quick questions. On UnityPro, I want to open and quickly read tags from a .STA files witouth opening the program. I have 30 plc...
152
